Quelle est selon vous la différence entre ces deux modèles, si différence il y a :
http://cgi.ebay.fr/ws/eBayISAPI.dll?Vie ... 0056502387
http://cgi.ebay.fr/ws/eBayISAPI.dll?Vie ... 0057786851
Plenum VVC
- Jean-Michel
Il me semblait que le K des dernieres S1 et premiere S2 etait le meme, seules differences majeures, ECU et systeme d'allumage
http://www.elises.co.uk/models/s2/index.html
Sinon
Si je me souviens bien, la boite a air est pas la meme et possede un autre capteur de t d'air
The standard 1.8 K-series engine remains but Lotus and added their own Lotus K4 ECU and on-board diagnostics system to ensure EU compliance until at least 2004. With 120bhp and a close ratio gearbox as standard (the larger 17" wheels negate some of this effect), it reaches 0-60 in approximately 5.6 seconds and 125mph. The gearing provides a 0-100mph time of approximately 17.5secs and mph/1000rpm figures for the gears are; 1st 6.1, 2nd 10.1, 3rd 13.5, 4th 17.1, 5th 20.9. The speed limiter operates at 6950rpm. At 80mph in 5th this equates to 3830rpm which is not quite as relaxed as the mk I's 3300rpm but is not quite as manic as the 4000rpm of the 111S.
Sinon
L'ECU est la difference principale, y a une meilleure induction et un meilleur pot d'echappement.luckyou34 wrote: Ps: quelle différence entre vvc 145 rover et vvc 160 rover?
