Quelqu'un a il fait la conversion ?
http://www.elise-shop.com/index.php?mai ... cts_id=130
Modif phare S1
- Contact:
C'est peut etre des cibie qui equipe les 4L mais ce sont pas les memes que les S1. Les 4L ont les veuilleuses separees et pas les S1
[edit]
Les loupiottes a cote des clignotants
http://elise-faq.info/index.php?title=Lights
[edit]
The headlamps are manufactured by Cibie, but are NOT the same as used on the Renault 4, despite being the same diameter (they actually contain sidelights and have a different lens assembly).
They are 6" in diameter, and have the following code numbers:
CIBIE : CBC 067689
VALEO : 067689
The headlamp mountings (not the headlamps themselves) are notorious for rusting in situ, and the only solution for this is to replace them with a non-corrosive item (available from several 3rd party stockists). This needs to be bonded to the glass fibre and set up properly.
When replacing the sidelight, please note that the holder is purely push-fitted into a grommet on the lamp, so watch out that you don't lose the bulb into the clam when replacing.
