http://www.autotechnique.fr/index.php?m ... cts_id=179
http://www.obdkey.com/
Prix unitaire : 113 euros.
original email a écrit :Hello Bill
Thank you for the enquiry and your interest in the OBDKey (www.obdkey.com)
product range.
I found your system and think it could be a usefull toy for my Elise S1
K-serie (rover ECU).
Could you let me know what I could do with this? <<
You can read the sensor data and any fault codes which the engine management
ECU is reporting.
read data, issue but could I damage the ECU itself?
No this cannot damage the ECU. The OBDKey uses the same communications that
would be used at a Lotus garage.
The bluetooth seems great. could plug it on my old IPAQ 1940 (during
runs)and my Ibook (servcing)<<
If your iPaq has Bluetooth then that will work fine. I will find out what
software is available for the iBook.
Would you be able to provide an extention, With an extention lead, I could
leave the Key in the Booth and connected all the time (make it part of the
car).
I think we could do that, but bear in mind the OBDKey is only 60mm in total
length so you may not need the extension?
Kind regards
Sinclair
Sinclair Easton
KBM Systems Ltd
101 Hutton Grove
London
N12 8DS
http://www.kbmsystems.net
Tel +44(0)208 4455008
Mbl +44(0)7973 747457
KBM Systems Ltd. is a limited company registered in England and Wales.
Registered number: 5770258.
Registered office: 101 Hutton Grove, London. N12 8DS. VAT number:
GB887965339.
@ Key, tu l'as finalement pris ou pas?
