Remplacement des durites du circuit de refroidissement...
Publié : sam. janv. 15, 2011 11:06 pm
Hello,
J'ai besoin de vos lumières, je compte changer les durites du circuit de refroidissement et monter un PRRT... le PPRT est en route, mais pour les durites j'ai un soucis. Chez eliseparts ont me dit ca:
"If you have a PRRT kit fitted you will not require hose numbers 16 & 20. List below of what I feel you will need.
Hose No. 1,2,3,4,5,8,12,15,18,19. You will also require either hose no.11 or 13 but it depends on what you have on your car. I would advise to check these hoses look the same as what you have installed on your car prior to order just to be safe."
Sinon il y a ca de dispo:
http://cgi.ebay.co.uk/SAMCO-SILICONE-CO ... 3f0474360e
D'avance merci..
D'avance merci..
