Hier alors que je tournais sur un circuit mon accélérateur s'est bloqué et continuait à accélérer alors que je n'avais plus le pied sur la pédale. Il me semble pourtant que la pédale était bien en position haute et à force d'appuyer dessus et de la relever avec le pied tout est rentré dans l'ordre au bout de quelques longues secondes.
L'un de vous a-t-il déjà eu le problème ? Que dois je vérifier pour être certain que cela ne se reproduise plus ?
Merci.
Accelerateur bloqué
- fentuz
ca pourrait pas etre lie a ca?
Accelerator
The pivot bolt can work loose on the complex cable mechanism under the dash. Trying to resolve this problem by adjusting the cable will result in partial throttle opening. The pivot bolt works loose gradually and if you find it early on it can be fixed by re-tightening the bolt with a 7mm spanner and some time spent on your back in the footwell. If the problem has gone undetected for a while, the bolt threads will be damaged and it must be replaced. Using a bolt as a pivot is bad design since they are not designed with these stresses in mind. The problem is made worse by the nylon bush that is used since this allows the bolt to tip under stress. Even though a nyloc nut is used, the friction of the nylon is overcome by the pivot action working to unscrew the nut. A long-term cure requires changing the design. Replacing the nylon bush with a brass equivalent will also help. A picture (640 x 480, 53K) of the throttle linkage.
supertony
- richard_gilmour
